Unable to assign "scan" function to "top button" on APX6000
human8472
I would like to set my orange "top button" on my APX6000 to the Scan function. However the Scan option is shown as orange in my APX CPS. I am not sure why I cannot assign the Scan function to the "top button" on the radio.
APX6k
Do you have it assigned as a soft button in the menu? I learned you have to pick one or the other, hard assigned button/concentric or menu item.
human8472
That was the issue. I also had it in my menu. I removed it from the menu and it turned black allowing me to use it in the "top button". Thanks!
human8472
I have my APX6000 setup with three zones. An FPP zone and two other zones. I would like to be able to setup a scan list using the radio itself to select from programmed channels. However, I cannot figure out how to do this. I looked at YouTube videos that cover the APX 4000 but my radio seems to behave differently. I have my man down button assigned to "Scan" but when I press and hold on the man down button I just hear a short beep and I don't get a list of frequencies to add. Does anyone have any suggestion on how to go about setting up a scan list? If not on the radio itself, then perhaps using CPS (I have v25 for the APX). Thank you.
clbsquared
Isle of Wight County
In your codeplug tree, select “Scan List”. Add the channels you want in the list. Also, make sure your conventional and Trunking personalities reflect the scan list you’ve put them in.
There’s a help menu in the CPS that has a wealth of information you can use. It will explain how to do this and many other functions you may want to do.
Each button has the ability for two assignments. “Short press” and “Long Press”
