unable to change frequency while programming xpr 7550 with moto cps 2.0
roy77kahnman
I'm currently using moto cps 2.0 trying to program my xpr 7550. How do I change the frequency of the channel? When i'm programming the channel and try to change it, it just goes back to the channel 851.1052
K2NEC
39A
Ok that still doesnt answer my question. What radio are you trying to program and what frequency are you trying to enter?
roy77kahnman
I'm trying to program a xpr 7550. attached is my radio's specs.
it's currently stuck at 851.01250 for receiving and 806.01250 for sending.
i can't change the frequency whatsoever. tried changing to 453.2500, 460.2125
KevinC
Encryption
Super Moderator
I'm everywhere Focker!
The specs explain it all. Look at the frequency range, it's 800 MHz so you can't enter a 400 anything MHz frequency.
K2NEC
39A
That's not an XPR7550, that's an XPR7580. As stated above, you can't program a UHF frequency into an 800mhz radio. You got/bought the wrong radio.
roy77kahnman
it doesn't explain it all. yes i'm aware i can't enter anything in the 400 mhz range. but why can't i enter anything in the 850+ mhz range?
i can't enter ANYTHING. it's stuck at ONE frequency
Firebuff66
CT
Did you try a frequency it can take? It is locked out of most frequencies below 854mhz except the 8Call/8Tac. try a freq above 854 mhz it should go.
Also i would use the 16.0 version of the software, much more user friendly
N4KVE
PALM BEACH, FLORIDA
Pretty sure it’s the other way around. The Canadian EID lets you program frequencies above 866MHz.
Moto doesn’t want LE using Trbo radios for Npspac. They want them to buy APX’s at quadruple the price, so the freq’s are blocked at the lower end, where Npspac now resides. But since there is no Npspac in Canada, an EID was created to allow Trbo radios in Canada to be programmable in the 851-853 range. Npspac hasn’t been 866-869 since rebanding years ago.
ramal121
Lots and lots of watts
Calif Whine Country
Doesn't appear to be the case. I checked several models and CPS does allow entry in the range of what is specified in the device information. Funny thing, it takes freqs with a non standard channel step (see screen shot, this was a 5380).:unsure: Doesn't seem to be the cause of what the OP is having a problem with. I do not have a clue. Maybe they got the CPS from a shady foreigner?
