on sds 100 ny state police unable to scan tried settings no luck
Are the service types turned on?ok i used sentinel which uses radio ref data base im close to ny thruway tower not sure what issue is?
I too am in very close proximity to the NYS Thruway and have been listening since they were on VHF. ALL my other radios pick them up fine. I had a rather long discussion on here about it. A lot of really fine and helpful folks had great suggestions and tried to help. I was very appreciative.ok i used sentinel which uses radio ref data base im close to ny thruway tower not sure what issue is?
any other suggestions will be greatly appreciated please advisewow thanks everybody sounds like a scanner issue also i have a terrible time with static on vhf uhf frequencies fdny fdny ems nypd all uhf tried multiple flters etc never any luck no matter what i try lol
Zip up your Sentinel export and post it as an attachment on this thread so someone can have a look at your programming.any other suggestions will be greatly appreciated please advise
...and answer this!Nys police have conventional channels and talk groups on trunked systems. For starters, you should state which troop you’re trying
i download direct from sentinelall troops conventional and trunk are together in my set up
You're not going to be able to pick up all troops from one location. Post your Sentinel export so we can suggest how to clean up your programming. Keep in mind the more you scan at once (the more work the scanner has to do) the more traffic you'll missall troops conventional and trunk are together in my set up
DEC | HEX | Mode | Alpha Tag | Description | Tag |
2251 | 8cb | T | SP Haverstraw | NYSP Troop F Haverstraw | Law Dispatch |
What about it?yes but what about remainder of nysp?
Frequency | Tone | Type | Use | Confirmation |
155.5050 | 110.9 | R | Operations | 2025.03.28 W1KNE |
