Unable to sign in to radio reference with Chirp.
KingLazy
Unable to sign into radio reference to upload frequencies with chirp.
Chirp stops responding. I've uninstalled it. I've installed it. I've installed the new version of chirp and nothing. The moment I click on the Ok button instantly not responding.
KingLazy
The only reason I signed up to radio reference is so I can hook up the radio and upload frequencies and I am unable to do that should I cancel my membership now to avoid any charges since I haven't been able to use the membership? Thank you for your help thank you for your time
KingLazy
Apparently radio reference is not allowing me to sign in with a specific zip code with chirp because I tested other zip codes and they worked
AK9R
Staff member
Super Moderator
Central Indiana
Perhaps you may want you Reiterate what site you are sending me to.
If I reiterated what site I sent you to, I would simply give you the site address again. I don't think that's what you want.
Perhaps may you want to offer some help.
I have no help other than to direct you to the authors of Chirp and their support mechanism. Your problem is with Chirp, not RadioReference.
Is it possible that there are no frequencies associated with the ZIP Code that doesn't work for you? Are you entering a valid ZIP Code? These are questions that Chirp support would probably ask you.
