IanWraith
Hello All
I have just uploaded DMRDecode build 57 to the usual place ..
https://github.com/IanWraith/DMRDecode/downloads
Note that from this build onwards you will need to have Java 7 installed to run the program. To find out which version you have installed go to a command prompt and type "java -version" if you don't see something like "java version 1.7.0" or the program doesn't run then you need to upgrade. The upgrade can be downloaded from here ..
Oracle Java Runtime Environment 7u9 Downloads
Build 57 should decode the Connect Plus CSBKO 01 FID=6 PDUs but I can't test this so would be grateful if one of you could. Also what other changes are needed ?
The code changes can be seen here ..
https://github.com/IanWraith/DMRDecode/blob/master/src/com/dmr/CSBK.java#L231
Regards
Ian
Regards
Ian
