Unication Alpha frequency ranges?
MM0DSM
There are 3 different versions of the Unication Alpha series pagers, each covering different frequency ranges.
Band A is 143.000-153.000 MHz (also quoted as 143-152)
Band B is 153.000-163.000 MHz (also quoted as 153-162)
Band C is 163.000-174.000 MHz
My question is: Will the pager and programming software allow me to program slightly outside these ranges? I can only seem to find pagers which cover band A (143-153 MHz), but I need a frequency of 153.350 MHz. Will a Band A pager accept this frequency?
MM0DSM
pro106import
Milford, Ct. perched high above Long Island Sound
MM0DSM
I have the G5 and even if I try to enter a frequency 5 Khz outside the allocated range of my unit, it disallows it. You can download your PPS and give it a try in advance if you like.
w2lie
New York DB Admin
Long Island, NY
I'm a Unication dealer. The Alpha Legend Secure has a range of 152-164Mhz. I can double check for you and see if that range is still available if you'd like.
