Unication Alpha Legend
MedicDavid78
Central NC
#1
I have a question... I currently use a Unication Alpha Legend pager for my agency. However the frequency we use is about to change from 450-mhz band to the 470-mhz band, and from what I've been told Unication alpha pagers don't go past the 470. The frequency I need is 471 so it's not too far off. Is there any way to mod a pager OR hex edit the PPS software to program it to allow out-of-band programming? I can't imagine my pager not being able to handle 471 when it already handles 450 range. Thanks!
ed3750
Palm Beach County, FL
#2
Unication has four UHF versions of the G5 700 - 800MHz pager. My G5 covers the UHF band 450 - 520MHz. Therefore, the PPS program can handle the frequency, don't know if your pager can handle it, but would believe it's close enough.
phirephoto
Fremont, CA
#3
The OP is talking about an alpha pager - completely different :)
MedicDavid78
Central NC
#7
Okay scratch my last post... I have an update. My Unication AlphaLegend pager is currently on 453 MHz, however my model stops at 460.000 MHz and the frequency I need is 460.6125 MHz and the pager program software won't let me program out of band not even that little bit that I need. So now I'm forced to buy another pager... I do have Hex editing software of there was some way to hex edit the .exe of the program software to extend the band limits... Therein lies my dilemma...
Unication_David
Unication Representative
Raceland, KY
#8
Or i could just ask engineering to expand the band by a bit.
MedicDavid78
Central NC
#9
That would be awesome. But I don't want you guys to change your limits just for 1 person. If there were more people I would say sure. OR, is there a way you could have engineering modify the program for me and eMail the file? Is that what you meant? LOL
