Unication G Series PPS
#1
I have been busy with other things recently. I was preparing to use the PPS and I just wanted to confirm that V0.3.5 Beta01 is the most current programming software that has been released to the general public. I
tried emailing P25Firmware@Unication.com twice, but I received no response.
Anyway, can anybody here verify that V0.3.5 Beta01 is the most current?
phirephoto
Fremont, CA
#3
I just e-mailed David - I sent an e-mail and didn't get a reply either - BUT I already e-mailed a month or so and got the reply. So if their auto reply is configured to only send once per e-mail address, that could explain it. If you've never e-mailed it, you should get a reply - assuming it's working.
Did you check your spam folder?
BenScan
#7
Unication David or anyone else who can answer,
Is there a way to copy profiles between different band G4/5s? I have a G5 700/800/VHF, and want to get another 1, or maybe 2, but might like to go with the single band G4 to keep the cost down, or the G5 700/800/UHF for more coverage. Obviously, you cannot program VHF on a UHF model, or single band, or visa versa, but it would be nice if I didn't have to re-enter all of the 700/800 P25 Trunking stuff I've already done for my current version.
Thank You,
Ben
WaveJam
Frederick, MD.
#8
Bump... Anyone able to answer this? I have a G5 profile created (just one 800mhz system in it) and I'd like to push this to a G4. Is that possible? I exported the profile, imported it back in as a copy and then was thinking that I would change the hardware type to a G4, but it doesn't look like you can do that.
Thanks.
