Unication G1 issue
#1
We have a G1 connected to our intercom system being used as our station alerting system. Every time it activates the pager 'squelches' and continuously has static,similar to as if you were pushing the button on the side, sometimes for a prolonged period of time. Is there a setting that can eliminate that so the pager goes silent after the tones and/or voice message is complete?
Unication_David
Unication Representative
Raceland, KY
#2
Yes, In tab H receiving portfolio settings select your knob position and change your reset mode to Delay and Auto. Set your delay timer as well, this should resolve the issue.
