Unication G4/G5 Firmware 1.2 released!
picscan
CA
Is there a way to save the old firmware to switch back if I don't like the new?
GTO_04
Noblesville, IN
Don't uninstall the old firmware version until you are comfortable and satisfied with the latest version. Just make sure you are using the firmware you intended when you program your radio.
GTO_04
picscan
CA
Okay, excuse me for being a bit tech ignorant but is the firmware built into the old PPS or is it separate? If it's not, where does it end up when it's extracted?
N6ML
Firmware is not installed by PPS. The previous version (1.10) of the firmware originally required sending your pager to Unication for upgrade (which enabled Phase-II). Then they came up with an online updater tool, but that had issues. I think they finally made the image available for download, with the offline updater tool. I found this in my downloads folder, but I don't remember exactly how I got it. I'm not sure if downgrading firmware is even possible. I've never tried. I wouldn't recommend trying unless Unication support advises to do it....
MaXKiLLz
Florida
Figured out a way around the annoying “repeating audio” when using bluetooth or the amplified speaker. Seems it happens the most when a channel in PPS is set to "Trunking TG-Scan" with multiple TGID in the "List Members". I decided to create a duplicate channel in PPS and set it to "Trunking TG-Monitor" with a single wildcard in the "List Members". Lo and behold, no more repeating transmissions. I tried adding my known TGID to the TG-Monitor channel and the echo started again. Seems it's something to do with scanning known TGID. So I set that channel's alias to "PD SCAN BT", left it with the single wildcard and use it when scanning with BT enabled. Hopefully Unication is aware of this issue and will correct it in a future firmware.
tglendye
Blue Ridge Mountains, Shenandoah River
With 1.2 I have had 3 occasions when the pager has activated but no voice traffic was heard. I thought the keypad lock may have played a roll, but the last time I had it unlocked- and I am not actually sure if it was locked the first time it happened. But this is a major improvement from 1.1., where 2-tone did not work correctly. It would alert, but certain traffic would pass through without the tones. We use a Harris P25 Phase II system.
WaveJam
Frederick, MD.
We need the ability to disable voice buffering when using a bluetooth headset or amplified charger. The repeating echo is starting to get on my nerves. :confused: Looks like I’ll need to revert to 1.1 until they get this fixed.
I'm in the same boat.. Its on my nerves. How do I dig up the 1.1 firmware to downgrade? And will I need to downgrade my profiles that were just upgraded in the latest PPS?
hfd26
Send an email to unication tech support and they will send you a link. They told me if I went back to 1.1 version I would also have to use the older pps with it
hfd26
If I can't get my 2 tone over p25 figured out I might have to contact him and see if he can help me there
WaveJam
Frederick, MD.
FYI... I pinged Unication tech support about downgrading my firmware (since I got my pager direct from Unication) and when asked about the echo issue, they replied: "We are aware of this and have some amp chargers here and are trying to duplicate the issue. Once we can duplicate the issue, we will forward our findings to the engineering team." on March 20, 2019.
letarotor
Arlington, TX
Then they need to take the charger I have and they will have no problem duplicating the issue. I'm still not sure if this is a problem just a few of us are having or if it's a problem a lot of people are having?
Sent from my SAMSUNG-SM-G930A using Tapatalk
Sent using Google Voice to Text. Please excuse any errors I could not see or catch.
Brian (COMMSCAN)
markjrenna
NJ
One thing I notice is when I have my G4 and G5 on the same P25 NJ ICS system there is an echo between the two as if one is slightly behind the other when receiving. Don't recall this prior to this firmware. Related?
