Unication G5 and control channels
blackbelter
Hello,
Would inputting all the control channels along with the primary and alt frequencies in a unication G5 a good idea?
Thanks in advance,
N6ML
Not much to go on here... If you're asking about a single-site P25 system, you should program it with all of the control channels (primary and alternate), in case the primary is down for some reason.
If you're talking about a multi-site regional system, and asking if you should program the control channels for all sites into a single system, I'd generally recommend that you do not do that, because you will have no control over which site the pager "locks onto". It will pick what it perceives to be the best site initially, and will remain on that site until the error rate exceeds a threshold, then it will search again for the best site to lock onto. One issue with this is that often not all talkgroups are carried on all sites in a large regional system - e.g. a city police dept's channels would only be carried on sites near that city. You may find yourself locked onto a site that doesn't carry the talkgroups that you want to listen to. Instead, program separate systems including sites that cover the areas that you travel within, and knob positions (perhaps in separate zones) that use those systems .. then you can be in control of which sites you want to listen through.
