Unication G5 DMR Private Call Talkgroup
JASII
Memory Capacity
With Uniden, a talkgroup can be created using i0 to monitor all Private Calls.
With Unication would that work or is there some other talkgroup that can be programmed to receive all Private Calls on a DMR system rather than using Wildcard and hearing everything?
There is no DMR wildcard for talkgroups or private calls, you either enter the TG/radio id you want to listen to, or you use the Monitor Mode and hear everything.
