Unication G5 Upgrade Question
JASII
Memory Capacity
My Unication G5 currently has 128 zones. My understanding is that the most current firmware only has 64 zones. When I do the firmware upgrade, will all of the data for Zones 65-128 be wiped out?
BenScan
D/FW
When they first put the limit on the zones a while back, I had files that had more than the limit that were automatically imported into the new PPS, that would still work. I made the mistake of deleting some of the zones, to where I had fewer than the limit. Then I couldn't add them anymore.
I recommend you backup your files, try the PPS, and see if you're still able to work with it. If you want to send me a copy of them, I could try it with the latest version of PPS and firmware that I've been using.
APX8000
Sarcastic Member
AES-256 secured
Post up the results of your tests. I’d be interested in knowing as previous versions brought over some of my zones that had exceeded the limit (but was under 64).
mkinkade
Central Ohio
Mine had 128 before the update. Backed it up. Restored it after the update, and still have 128.
JASII
Memory Capacity
I checked my G5 and have Firmware Version V0.90-0.14A-R11P. Is that still available somewhere? I had it on my old computer, but I am using a different computer now.
JASII
Memory Capacity
Thank you to everybody that responded. My Unication G5 shows:
Firmware Version V1.10
My PPS: V0.3.12.06
So, I think I am current on the G5 firmware and the pager programming software AND I do still have 128 zones.
