Unication Radio Reference Import
Acox565
Hello all, does anyone else have an issue with the radio reference import button being cut off with the PPS software? I don’t have any option to “scroll over” to it or anything of the sort. I have loaded and unloaded the software to see if that would help. If you have any solutions, I would greatly appreciate the help
Enjoi19
Ontario, Canada
I suspect you're probably at too small a resolution.... I haven't seen a monitor at that in a while. You could try changing the scale to under 100% if it's an option, or find a bigger monitor to connect to.
K9KLC
Southwest, IL
I always have to click on the maximize/minimize button till I can see it. In my case it's an old laptop and resolution issues. I have to do the same thing to see the stuff at the bottom like save and such.
