Unication / Radio Reference
ttquattroman
Ridley
Hi, having real problems programming a G5 from Radio Reference. I have a premium account with RR and the latest programming software on my PC the G5 has the latests F/W. I can log on to my RR account with no problem, however when I try to log on via Unication the error says RR username/password is not recognised. any thoughts. Thanks Peter KM4JXP
ascoltone
Doesn't work that way. Same issue, You need to export the excel file from Radio Reference and import through the Unication software.
Hope it helps.
Hit_Factor
Saint Joseph, MI
Hope it helps.
That might work OK. It can be tedious and challenging for someone who doesn't work with spreadsheets and CSV files regularly.
However, I'm able to import from RR while using PPS. No intermediate steps required.
ascoltone
When did that change?
Kevin I had the same problem mentioned by ttquattroman and overcome the issue as I described since the option of importing the files is part of the programming software. I was never able to access to my account from the program.
jtwalker
Gettysburg, PA & Fenwick Island, DE
Still works fine for me when I last used it about two weeks ago. I often use direct import for system and sites, and use csv for talkgroups so I can more easily filter out service types I don’t want and encrypted TGs.
ascoltone
Thank you for mentioning, I will give another try, just provided an alternative that worked for me
ascoltone
So today I tried again and is the first time that program accepted my RadioReference log in. Thank you for the triggering the topic today because it helped to solve an issue that I had with a specific region that now have been able to properly import.
K9KLC
Southwest, IL
Glad you were able to get it working. While it's been a few weeks since I logged on, it's worked every time for me since at least Last September when I first got involved with Unication Pagers.
Hope it helps.
Alternatives are great, but so is correcting the problem, or seeking help to find out what the problem was, rather than giving up and telling people it didn't work.
ascoltone
Really? I just did it. Used PPS 4.01 and my RR username and password. Worked fine.
As I mentioned today, triggered by the post, I tried again and for the first time it worked also for me. I spent the morning doing a new pps.
When I wasn't able to join thrugh the software my RR subscription was active. Some few weeks ago I renovated, immediately after the expiration and didn't tried again until today.
