Uniden 980 Coils
CyberWarrior
Ft Lauderdale FL
I have been looking at some You Tube videos,on this radio.
In one of them,the guy tells you to spread the coils turns as 2-2-3-2 and the other ones 2-2-2-2-.
He claims that this will improve your AM upwards modulation.
Has anyone here tried this? If it fails,can I put the coils back,the way they were?
gewecke
Banned
Illinois
. Its NOT that simple, leave the radio alone ... don't believe all the crap you see on you tube! If you want more modulation, just use a preamp mic. 73, n9zas
gewecke
Banned
Illinois
I thought I ask. There is a ton of these "how to" videos on this radio.
I wish Uniden would put out a schematic on this radio.
. They probaly dont for good reason ... Its not bad for a cb, just don't try to fix what's not broke? :wink: 73, n9zas
prcguy
If you have some test equipment like a wattmeter, load and oscilloscope to look at the RF waveform, you can perform the steps in the videos since you can actually see what is happening when you move the coils around. Without test equipment it would be like tuning up your car by turning screws on a carburetor and changing the timing by twisting the distributor with the engine off, and expecting some improvement.
Just say no to stupid blind adjustments.
prcguy
KC4RAF
Davenport,Fl.- home to me and the gators and the s
Just as Gewecke and Prcguy posted,
leave alone what's not broken.
On youtube there are a few vids that are far fetched. (You believe in "flat earth", the moon hoax, etc.?) One guy I remember using a small metal screwdriver to tune IF, mixer circuits coils! Plastic diddo sticks for that adjustments.
Without the proper test equipment and other tools, you're just asking to make a boat anchor out of a good transceiver.
JayMojave
Mojave Ca
Hello CW: Modifying a radio is a lot fun and gives the user a great satisfaction. Many many radio enthusiasts always want more power, more audio, and to be loud and proud. Granted.
But you need to know what it takes to make a good mod. As an example you need at least 6 to 10 dB increase in your output power to double your range. That being said what little improvement if any in a output mod on these mass produced radios were they use the cheapest parts available to keep production costs down. A 6 dB gain means if the radio puts out 4 Watts, then 4 x 4 = 16 watts, and for 10 dB that 4 watts would be increased to 40 watts. Your wanting to modify a 4 Horse power radio into a 40 Horse Power radio. It ain't gonna happen with the stock factory parts. Some Mods can increase the out power and modulation, but only slightly.
I looked at the You Tube video that you talked about I believe, I want to see the before and after radio performance on a Watt Meter, Scope, and see what the output spectrum is, meaning did the radio increase in unwanted harmonics and such. Not the normal radio guy type of equipment everybody has.
Modifying radios is doable but requires technical knowledge and test equipment. When I was a kid we use to install a "Strap" (the term "Big Strap) or bypass a resistor in our General Radiotelephone Super MC=11A radios, this resistor was in series with the finial Plate circuit and gave us a like about 10 watts out, but then the modulation went down because the Modulator didn't have enough power to properly modulate the finial tube because it was drawing more power, requiring more audio power from the modulator. After a few years we removed the bypass wire and got louder.
I see some modifications were a amplifier is added to get more power out, but is expensive and needs a Tech to install. Good Luck.
The coils can be squeezed back into place if needed, but may not be the same after being widened, be advised.
Jay in the Great Mojave Desert
QUOTE=CyberWarrior;2511386]I have been looking at some You Tube videos,on this radio.
Has anyone here tried this? If it fails,can I put the coils back,the way they were?[/QUOTE]
CyberWarrior
Ft Lauderdale FL
Well as it is now,I dead key 7w and swings to about 12.The weak link on this radio is,SSB power.
The best it does on ssb is 10,I need to find out the number adjusting pot or pod for SSB.
gewecke
Banned
Illinois
Again, leave it alone Unless you have the experience and bench to tune it properly. The difference between 10 and 12 watts is 0 ... but its your toy, do as you wish. :roll: 73, n9zas
gewecke
Banned
Illinois
Same radio as the radio shack Htx-100, nothing special. Not legal for cb use however... 73, n9zas
gewecke
Banned
Illinois
. You could try to find the ALC on the schematic which might help on ssb otherwise I'd leave it as is... 73, n9zas
