Uniden 980SSB - "LOCAL"
Colin9690
Delaware County, OH
Lewis Center, OH
Hey guys,
If you press the RF GAIN button, a LOCAL indicator appears on the display. I understand what RF gain is supposed to do, but what does this mean when its displayed (and not displayed)?
RFI-EMI-GUY
Local means either the RF gain is at minimum or there is an attenuation in circuit.
Colin9690
Delaware County, OH
Lewis Center, OH
Thank you. So with that being said, I guess the absence of this indication shows it’s allowing the reception of more distant signals. Thanks again.
blakews2217
alton il
If you hold the button down for a few seconds (within 10) it will bring up the adjustment menu. Use the channel knob to change it. Press said button again to exit. You are right about the light, when it’s on, it’s limiting incoming signals. When it’s off it’s “wide open”.
Colin9690
Delaware County, OH
Lewis Center, OH
Ah, I see, looks like I got it figured out now. Still trying to figure out this neat little radio, but have zero complaints so far. Even figured out how to get rid of the loud "key beep". Thanks again for the help there!
blakews2217
alton il
Your welcome. I have only one complaint so far (because I’m old school) is some of the adjustments on the radio are set values, not infinitely adjustable. The pros defiantly out weigh the cons. I have talked well over 300 miles bare foot with this radio on 38LSB and with reports of “ sounds like your in my driveway”. Stock mic too
Colin9690
Delaware County, OH
Lewis Center, OH
Wow happy to hear. I was meaning to ask about SSB. I hear lots of people talk about 38 Lower. Is that kind of like the informal "Channel 19 AM"? I've been itching to try some SSB contacts but not sure if there's a "common" channel , so to speak. Just looking to increase my chances of finding someone on SSB to shoot the crap with. Thanks again for the friendly advice.
Colin
blakews2217
alton il
Colin
Its mainly what others in your area talk on, but the “calling channel” on sideband is 38 LSB. I’ve personally talked from Texas to Rhode Island, across Canada and even Alaska once from st.louis. All on a 980 with A99 and about 175 “helpers”. I’m waiting for the weather to break and stay dry so I can put up my new antenna setup. My last one toppled in the yard and My brother came over and did not see it under the snow. Now I have 2 Antron antenna, one has a broken bottom section and the other is ready to mount
Back to the point, my locals talk 23AM. I’m close to a few major highways so I can almost always get someone on 19 AM. 38LSB is the long distance channel for me. The bearcat has a scan function. Use it and see where the activity is. All it does is flip through channels until one breaks the squelch, it will pause then continue.
Colin9690
Delaware County, OH
Lewis Center, OH
Good deal, yeah I've been using the scan feature on the USB / LSB when I get board of the usual AM 19 debauchery, haha. Since you have been more than helpful, I have one more question about the clarifier. On the "course" knob, I can feel a slight detent, or default position in its movement near the middle of its travel. However on the "fine" knob, I can't feel a detent. Is the default position for the clarifier all the way to the left (like the squelch and volume)?
I hope that makes any sense at all, and thanks a million good sir!
Colin
blakews2217
alton il
Colin
Glad I can help,the fine clarifier knob is like the Course knob, but the lack of a detent helps with getting exactly on where you want and not listening to a bunch of people that are high pitched.
Colin9690
Delaware County, OH
Lewis Center, OH
Understood. So I guess the Coarse knob's default position is at the detent in the center, and the Fine knob's default position is full-left? Many thanks.
robertwbob
KE0WRU
Northeast jasper county,missouri
If you have a new version 980 there is a push and hold button that kills that beep. Id have to read a manual but i think its the anl nb button.google search both early and late versions.easy to tell them apart.older version you have to open and lift a leg on a doide or something.cant remember but im about to download how to do it and shut that beep off in my early 980
Retroradio
Ontario
Yeah, that beep is annoying...I have 2 of the older 980s and my only complaint as it’s a fine radio otherwise. Mine sits on top of my GE Superbase and depending on my mood dictates which one I use.
