BCD536HP: Uniden Audio Recording WAV File Specification
#1
I am interested if anyone has the header data specifications for the Uniden audio recording (wav file) .. for the 536HP (I imagine that the 436 is the same).
What I need is mostly the length of each item .. ie System Name, Department Name, Radio Tag etc. I guess I can make a long long name in Sentinel and see how much gets chopped off in the WAV file when it does a recording.
But I would like to find this data if anyone has it ?
#2
I just went with 48 for the tags .. I never do them that long so it works.
