Uniden BC796D & Indiana SAFE-T System
w0ktb
Farmersburg, IN
Hello all, I got a used BC796D scanner in the shack a little while ago, curious how to program it so I can listen to what is happening on the Indiana Safe-T system. I've got the frequencies but there are so many options to set, I use to have a Radio Shack PRO-94 but I think someone stole it from me (lame). The counties I am interested in listening to are Sullivan and Vigo...
Any advice is appreciated.
Thanks & 73
Trey, W0KTB
mikewazowski
Staff member
Central Ontario
Since this is an area specific question, I've moved it to the Indiana forum.
W9NES
Indianapolis,Indiana
w0ktb, I own a Uniden 796D and use on on the safe-t system here in Indianapolis on the ISP 52 Indianapolis Tower along with the Boone County Simucast system. The 796D is a great scanner to use..I will send you a pm on how you can contact me. I can help you program your scanner.Thank You.
GTO_04
You will need to set it up for rebanding, but other than that it should work fine.
GTO_04
