Uniden BCD396XT Assistance Needed
terryyvr
Vancouver BC
I just noticed display screen is showing "scan mode" "nothing to scan". Could someone help me get back into the scanning mode again thanks.
signal500
Florida Panhandle
Press the function (top button on the side / you will see the letter F in the upper left hand corner of the screen) and then a number on the front to start scanning a system.
For example, to start scanning system 2, press the function key and the number 2
I hope that helps.
terryyvr
Vancouver BC
Hi Doug I pressed the "function" button & the "F" did appear then I hit "2" & nothing seemd to happen. It seems as if it's locked?
