Uniden BCD996XT Pre Loaded Programming
jrscpu2004
Selden, New York
#1
I see from the Uniden Manual there are Pre Programmed areas around the USA that are available.
Unfortunately, New York State isn't one of the locations available. Did Uniden ever update their list of
Pre Programmed areas by any chance? Would this be part of a Version Update if so? Thank you.
