Uniden BCT15x serial number
#1
Is the esn suppose to match the serial number on the unit itself? Didn't know if this was a new clone hack or if my repair guy pulled a good one on me.
#4
Serial Number Question Bearcat BCT15x
Is still doesn’t look like they are matched. Does it to you?
Here is the information:
The box: S/N 88000493
Back of unit: 361z88493
On the scanner it says:
Firmware Version
Version 1. 06. 00
SN 336 26 08400 3383
My question is that is the box, back of the unit and the SN under the firmware supposed to match? I understand about replacing the z with the 3 numbers. It still appears to be different.
