uniden bearcat BC147XLT Help
cnbhale
Hi all I am very new at this . Someone gave me a uniden bearcat BC147XLT scanner its an older one i would like to try make it work or maybe its to old i now lots about computers , sat dishes but nothing about scanners any input would be nice
THX ALL
W6KRU
Vista, CA
That is a pretty limited scanner. If you let us know where you're at and what you might be interested in, we would have a better idea of the usefulness of it.
cnbhale
Hi Im from Nova Scotia Canada. i dont really now what i want the scanner to do iv never had one before prob to just lessen to the police station
ve1sef
Halifax Regional Municipality, NS, Can
I belive the scanner itself should be easy to program, did the maunel come with it?
If not, going by memory as I belive its indentical to the bc145
Select the channel you want to program
press Program.
enter frequency using number keys(i.e. 153.830).
Press Enter.
If you want to confirm the frequency, press maunel, select channel, then press review button.
Where in Nova Scotia are you? Might be able to help.
cnbhale
Hi Thx for the reply .... I live in New Glasgow Nova Scotia. There was no manuial with it not even a antina
Can i use any antina on it .
THX
davidmc36
South East Ontario
Because that scanner is not a trunk-tracker nor does it have 800hz, you will be SOL for the province-wide system that RCMP (digital) and EMS are on. Maybe you can get some local stuff though, and some small fire departments. Look here and click on your county to see what might be available.
http://www.radioreference.com/apps/db/?stid=107
Cheers
ve1sef
The above reply is correct that you won't get the provincal trunk system. You will be able to monitor
the local V.F.D.s and municipal police. I think an antenna with a motorola plug on it will work with the
bc147. The person to ask would be Bill at Nu-Com Communications, he sells and repairs scanners, his
shop is in New Glasgow. He may even have an antenna for it.
