Uniden close call on construction sites
mike619
If on a construction site would Uniden close call be effective in finding out what frequencies the companies are using?
IC-R20
LoBand Nation
Oh yes, very. Depending on how strong the sea of there signals in the area are you can get hit on them off site but nearby depending on the antenna you use. Using a 3 foot telescopic on my BC92xlt I can get 200mw FRS radios from 500 feet, 4 watt handhelds from 1/4 mile, and 50 watt mobiles from 1.5 miles since the spectrum is not too crowded at once where I live. A little over half of that on my 436HP since it's not sensitive but yeah close call is made for that. That's how I log most businesses and originally why I got the 436HP (I can record with metadata eliminating the need to listen live and making hiding it easier. I either belt clip it and pull my shirt over it or if it's cold enough put it in my jackets interior pocket and walk into a business.
Whiskey3JMC
Just another lowly hobbyist
Philly burbs 🇺🇸
Worth a shot but if comms are DMR simplex, close call is virtually useless. I'd suggest checking common itinerant & business frequencies. Don't forget FRS as well. If construction company name is known try searching for licensee via FCC ULS or maprad.io (US or Canada) for fixed base and/or itinerant licensing. Also be familiar with the radio rental shop licenses / systems in your area and scan them for undocumented talkgroups (ID search) or generically-named "construction" talkgroups in the RRDB, this is when it helps to be armed with a DMR & NXDN capable receiver. Keep in mind not all construction companies utilize LMR radios.
mike619
What do you have your squelch set to while in close call?
IC-R20
LoBand Nation
Same as for regular listening with the exception of LoBand sometimes when there's too much noise then I set it to 2. The squelch is pretty smart on these radios so I never had any issue with falsing. I'll just hit the attenuator or collapse the telescopic antenna if I want to limit what I get hits on.
radioman2008
Batlabs user Wazzzzzzzzup (2001-Present)
System 1632 Tampa Bay Florida
most of my unidens are set to 2 all the time.
i use mine around the mall, it is like a ghost town in there.
I walk around malls scanning in discovery mode (so it stores audio in specific folders for each business). usually ill set one uniden on 466-470 and another from 464.4625 to 464.55
Tillys uses 464.4625 in my area, and 464.50 and 464.55 are easily active with some store radios.
