HP-2: Uniden Homepatrol-II list vs zipcodes
Brooklyn NY
#1
Hello all I am looking to buy the hp2 and i have a quick question i know it uses the zip codes to find frequencies but my question is why does it come with the software with the frequencies in it do you write the list into the home patrol or does it just find whatever u want just by Zip codes can somebody please explain this to me
chief21
Summer - western NC; Winter - Tampa Bay FL
#2
The Sentinel software allows you to download and update the frequency database from time to time so that it remains current. The software is also used to apply firmware updates to the HP2. Once you get more comfortable using Sentinel, the software allows you to create custom frequency lists (Favorites) for certain areas or types of monitoring. These "Favorites" can then be loaded into the HP2.
bdp278
New Orleans, La
#4
Before u purchase a home patrol u may want to investigate if any systems in your area use multi sites, which is called simulcast sites. If so u may want to consider the SDS100 it uses the same zip code lookup as the HP, but receives these simulcast sites much better than the Home Patrol units.
Brooklyn NY
#7
I am in NYC Brooklyn , Thank you sir for the help everyone thanks just quick question if i load the radio with an updated list then im listening to whatever i put in the radio so then we dont use the zip code correct ?
W8RMH
Grove City, Ohio (A Bearcat not a Buckeye)
#8
You will need to use your zip code (location control) when monitoring the database, otherwise the scanner will not know what to scan. If you program 'favorite lists' you don't need to use the zip code feature unless you want to.
Below is a link to a video made by UpMan from Uniden describing how to make favorite lists from the information in the database.
https://youtu.be/MOo9iJ8RYWM
rbrtklamp2
Dupage County, Illinois
#10
LOL wrong link man! But my grammar is better and now and I have an idea of how to make my reports more interesting
Sent from my SM-N960U using Tapatalk
