cbskate19
Does Uniden only work well up 16 GB while it says that it supports up to 32 GB?
Or does Uniden only work well up to just over 2Gb of data while it says that it supports up to 32 GB?
https://forums.radioreference.com/threads/replacement-sd-cards.340206/page-2#post-2663771
...For Uniden, there are no issues with larger cards, other than when you reach a certain number of folders, it'll refuse to record, which is about 16-24GB depending on transmission length. I have 32GB and had no problems. ...
- kandrey89
- Post #29
- Nov 6, 2016
- Forum: Uniden Tech Support
https://forums.radioreference.com/threads/rebooting.307293/page-5
Well, that didn't take long.
Brand new Transcend SD card - it went directly from the package to the PC slot, prepared with Sentinel and installed directly in the 536 -- left untouched and recording --
It only took just over 1 week before the radio rebooted itself (I just happened to be sitting here this morning and heard the radio "beep" following the reboot).
Recording 1: 2017-12-01_13-26-53
Last recording: 2017-12-09_09-29-10
Upon removing the SD card and pulling the recordings, once again, there is just over 2Gb of data on a 16Gb card - roughly 43,000 recordings.
I was actually expecting to come back and report that this made a difference - it did not. I see no difference with a "recommended" brand new card.
Not much else I can say.
(In case your are wondering, the radio is running FW v. 1.11.31 but it has done this reboot thing on every version of firmware - as does my 436).
