HardrockF350
- Joined
- Jan 7, 2019
- Messages
- 14
- Reaction score
- 2
It has been a long time since I had a working scanner. my first scanner was back in 1990, I purchased a radio shack PRO-34 100 channel scanner, and how simple it was to program it. this week I purchased a uniden sds-100 scanner, and I am using the sentinel 2.00 rev 10 programming software. when I select a conventional channel, then append to favorites all looks good, and it scans right. the problem starts when I select any of the palmetto 800 channels/groups and append (add) them to favorites, write them to the sds-100, and the favorites are listed but not channels/frequency/info are not saved in the scanner, only the palmetto 800 channels are not working/saving right.....
example: after I have updated the firmware and database. make a favorite group called SCHP TROOP 7, expand the listing USA,SC, Bamberg, statewide, palmetto 800, and the group I want to add/append is SCHP Troop 7. right click on that group just that group, select append to favorites and I select the favorite I made before hand (SCHP Troop 7). next all of the palmetto listings/groups are added to my favorite SCHP Troop 7, not just the one I selected, but all of them. what is causing this? I have saved this list to the scanner, and it doesn't see any info/data/frequencies. even if I delete or avoid all the other unwanted frequencies it doesn't work, scanner states scan mode, nothing to scan..
I have even let the scanner select the data base from zip code, and it will add all of the palmetto 800 groups to the full database. next I tried to manually go thru those freqs, find the Ch 99 disp in orangeburg (I hear HP talking) and I press E(yes) button and add to my favorite. so far looks good, it is there in the list, but when it scans all of the palmetto 800 freqs are being scanned one by one with the other freqs I have added.
I have searched online for this same problem and found noting, reset the scanner 2 times, redone/reselcted the favorites many different ways, and the same thing happens. So what am I ding wrong???
I am grateful for your help.
thank you
thank you
