Uniden SDS200 Memory Loss
garys
Eastern MA
#22
I'm pretty sure that it was a battery, as at least one member here changed it out on his before the RTC repair campaign started. The problem turned out not to be with the battery per se, but with circuitry.
The x36 models had to be plugged in and on for several hours to charge that supercap. Did the OP leave it on overnight to charge it?
mancow
N.E. Kansas
#23
I was one who did that and yes it continued to drain.
