Sensitive and selective, that would be the BCD536HP. The SDS200 are in some situations as sensitive but much worse in the selective department and even a disaster in high RF level environments.
The TRX-2 has a tad worse sensitivity than BCD536HP, but not much, but suffers from some kind of overload issue in VHF.
DMR decode are better in the TRX-2 and can decode really noisy signals but using the same antenna signal a Uniden will have less noise and the squelch in TRX-2 will need to be set much higher, so it will decode pretty much the same from the same antenna signal. Uniden still has some issues decoding DMR control channels and you have to spend another $50 for the DMR decoder. A SDS scanner are only intended for coping with simulcast systems as the x36 scanners have the exact same functions and features, if we disregard the color display, But the BCD536 has WiFi hotspot that your mobile phone can attach to and work as a remote client with iPhones or an Android phone that has an older firmware. If you have a TRX-2 connected to a PC you can do pretty much the same using Android Suite.
I do not really see the point in selling SDS scanners in Europe, considering the bad RF handling and higher cost compared to x36 scanners.
/Ubbe
