adsbgreenock
Hi Guys,
I didn't know where to post this so mods delete or move if inappropriate and accept my apologies.
OK I have been trying to pick up some DMR stations some 10-15 miles away from me with a nearly newish uniden sds200e.
The uniden is missing these stations on the receive with the same antenna (Diamond X50n) my rsp duo is also hooked upto (not even a flicker of change in the noise or RSSI meter).
This is really starting to piss me off to be honest, as Uno shows at least a signal 8 on the METER and decodes the voice channel not a problem.
I have tried another two antennas, one a yagi and another colinear in my loft and the uniden skips on past the frequencies in search mode.
Even when i Hold and sit on the frequency. I get ZILCH.
The Duo is a different story and even the normal rtl-sdr blog v3 receives OK. Obviously with the gain adjusted a little.
Is there an rf gain hidden somewhere that I am overlooking? It is much required I think.
Even playing around with the Global filters I am unable to even receive the UHF stations the rsp duo is receiving. It is not just this frequency either there are around 10 most showing at least a signal 8 in UNO..
I mentioned this somewhere else and received a snarl from some of the more fanatical uniden lovers.
Are there any rf gain settings in this scanner that can be accessed and adjusted I may have overlooked?
I just ordered a gps unit after searching everywhere for one but in all honesty I'm ready for boxing this radio up and throwing it on fleabay.
Any help is appreciated as always and thank you in advance
Kind Regards
Kind Regards
