SC230: Uniden USC230 Firmware
adsbgreenock
Greenock, Scotland , UK
Hello Guys, Bit of a Longshot but you wouldn't happen to have firmware for the usc230? The link is broken on the site.
I have rebuilt the handheld it was originally bought broken to pieces.
I fitted new power adapter jack. New bnc antenna port. Swapped the screen and replaced the battery compartment. But I need the firmware to get this little radio working.
Much appreciated and TIA.
Regards
dave3825
Suffolk County NY
If a link on Uniden's site is not working, you could try tagging @JoeBearcat . He is our Uniden representative and may be able to assist.
adsbgreenock
OK Dave cheers for the response . I'm kinda hoping I can get this firmware in have everything else . So if uniden don't have it hopefully some nostalgic scannerman has the firmware on an old PC or drive . What ya reckon @JoeBearcat ? Here's the broken link bud :
I guess its a stab in the dark given the age of the scanner . Gotta try though.
Thanks in advance
pro92b
Mutated Member
The firmware file you listed is for the SC230 only, not the USC230. My understanding is that the USC230 never got a firmware update so all the radios are at release firmware level. Outside of Uniden there is likely no place to get initial release firmware. That said, I am attaching the SC230 V2.10 firmware file even though I don't think you can use it.
  • SC-230_V2_10.zip
adsbgreenock
Hi pro92b thanks for your help .
Ah i see , different chips I would never have noticed if you hadn't pointed that out . I just seen the sc230 and thought it was good to go . OK I'll keep a hold of the file and wait to see what else is said , you're most likely correct.
Cheers again
JoeBearcat
Uniden Representative
That is a 'U model' (non-North America), so I can't help. I do not even have any contacts for that division. I am the rep for Uniden America.
Best to try a contact from the website for that division.
And no, the NA firmware will not work in 'U' models. (or vice versa)
