unident RCS talkgroup
#1
Hi all. New user, My name is Scott, I am a Comm Supervisor at Heartland. After a recent murder in Santee near my house, I saw a bunch of SDSO Detectives running around the neighborhood. After not hearing anything on any normal talkgroups, I was searching the South Loop and found a "unaccounted for" SDSO numbered talkgroup, with everyone encrypted. Anyone know what the channel designator is for talkgroup ID 34400? Also 34416 and 34432 are "unaccounted for" also. SDSO secret group??
Gene
San Diego CA
#2
Hi Scott. Welcome.
Recent changes have been made to the Law Enforcement talkgroups. Each Sheriff Station now has 3 Tac Channels.
Santee would be known as 40Tac 1, 40Tac 2 and 40Tac 3. The old INV channels became the New Tac 2 channels. The Tac3 channels are all encrypted and not monitored by the Comm Center. I believe that they are new talkgroup numbers. Substitute the 40 in the above example with 90 for San Marcos or 80 for Rural, etc. Assignment of Tac 1 and 2 is at the Stations discretion so in the case of Santee, Tac 1 may be used by Santee City Units and Tac 2 by outlying Units.
I am unsure as to whether the Tac 3 channels are now for the Investigators or whether they also have new Talkgroup numbers.
#3
Thanks Gene. After I sent that I read your previous post and guessed right away that 34400 was probably 50 TAC-3 coded. That makes perfect sense since I am in Santee. Thanks for the reply! Scott
