Union County FMA / Unlisted TG's
RadioDitch
Nomadic
Noticing something actively right now. Fire in Plainfield is winding down, and 453.1500MHz Union County Fire Mutual Aid Dispatch appears to be simulcasting onto TG 06-061 as normal, but also 02-143 which is unlisted.
Also another unlisted TG popped up today on the Union County TRS. 10-141, which the unit referred to as "operations channel".
NJEMT12982
NJ
I'm not sure about the activity on the talk group 02-143 but as for 10-141, that is usually active during big events/special events such as the annual Union County Music Fest which has been on going since Wednesday of this week. It is rarely used but a good t/g to have in your scanner/radio.
RadioDitch
Nomadic
Thanks. I'm guessing that has to be the Sheriff's Special Event since UCPD was on their normal event channel 04-030.
Also picked up another new TG today...10-151.
Tac-1
Linden, NJ
There a lot TG for the school emergency radio network i listed some that i have logged below
the schools test their radio about once a month with local PD
tg 02-143 may be union twp they simo ucma over that tg on there system
10-150 SERN Clark
10-154 SERN Cranford
11-007 SERN Roselle
11-002 SERN Roselle Pk
11-010 SERN Summit
10-153 SERN Westfield
11-011 SERN UC College
RadioDitch
Nomadic
Okay, cool. Thanks Tac-1. Guess you can add those two to your list of possibles then.
