Unitrunker - added feature maybe
puzzleriddle
bham, Bama
I would like to see each header on the main page be "sortable when clicked on at the top.. and if possible say i want to see all Fire dispatch call list i a certain time frame grouped together?? Am I making sense?
keep up the great work tho.
Most column headings are click sortable. The main exception are the history panels which are chronological order only.
If fire dispatch is a specific talkgroup, open that talkgroup (double-click on most grids) and click on the History tab. Scroll back in time to the event of interest.
puzzleriddle
bham, Bama
I am on the call history page & it's not sortable.. maybe I am running an older version... will look & try the latest if that is the case.
Thanks!!
Thanks!!
That is by design. As described above, it's only shown in chronological order (ascending or descending). To see the history for a specific group or user, double click, select the history tab in the group or user popup window and scroll.
