Unitrunker and Pro-197
wvscanner
Beckley, WV
I don't know what I'm missing. I have Unitrunker set at inline, 9600, n, 8, 1 on port 10. On the 197 I have set the settings to cc dump on.
When I turn on unitruinker I see where the lights are flashing green in the cable. I try to manual stop on the control channel as well set it on tune. Unitrunker does nothing.
Have I missed a step somewhere?
Highpockets
New Jersey
Try:
Inline
(scanner)
signal
start stop (used when needed)
115200
8
none
wvscanner
Beckley, WV
Thanks, that helped. I always thought because device manager reported the 9600 I had to had the software to report the same. I never had choose anything above 57600 because on a regular port I never could get it to work.
