Unitrunker Logging
Forts
Ontario, Canada
Quick question about logging in Unitrunker... I'm not sure if I am doing something wrong (or perhaps it's broken) but for my local EDACS system I have the 'Log' option checked, yet it doesn't seem like anything is being saved. I've been running release 14 for about 2 days straight now and both the R000001 and S00001 folders are empty, and when I check the History tab for any user or group the data only seems to go back for about 4 hours. Is this normal? I was hoping to be able check affiliation history over extended periods of time.
Thanks!
The depth in the history tabs is limited to 4 hours to keep memory use reasonable. Eventually I'll change the program to use the history files. This will free up some memory and allow unlimited depth.
Make sure site logging is turned on (in contrast to receiver logging).
Forts
Ontario, Canada
Ahhh ok I suspected that may be the case. Thanks for clarifying and your continued hard work!
