Unitrunker not finding freqs.?
mikey60
Oakland County Michigan
We need more information to try to answer your question...
What System?
What type of system?
What frequency range is the system in?
Are you seeing any data at all on the screen?
Mike
Cruiseomatic
Houston, TX
What System?
Mike
Motorola Type 2 Smartzone
Multi-Site
800 MHz
Yes, Just no frequencies are showing up. Trunk88 shows them but not UniTrunker.
Also no Target Labels or Source Labels. Do these need to be programmed by hand?
