UniTrunker problem / Enc showing up
ccfd7031
I've been messing around with Unitrunker and my 396xt. I have it decoding a local P25 control channel and most (not all) transmissions are showing up a (P) for encryption when there is no encryption used on the system. I confirmed with my other scanner by listening. I had been using pro96com and it worked find. I've got good signal strength so I'm sure it's a setting somewhere hopefully.
Has anyone ran into this problem before?
ccfd7031
Version 1.0.26.16 I think. It says Win32 also.
I'm also getting regular 4's with no P mixed in. It's not a huge problem but sure does clutter up stuff. I'm also getting 0 in the colum where the radio ID should be. I get the Talkgroup ID's fine. For example it shows radio 0 is talking on talkgroup 600. I think that might be showing a 0 due to it thinking it's encrypted but I'm not sure. I've got full signal and the software is showing aprox 70 on the health. I'm stumped.
ccfd7031
Here is a log file of the decode. If you need a longer log or anything just let me know.
The problem occurred near the beginning when I first started the log. It occurred on talkgroup 600 but does occur on all of them. I cut the log short since I figured that was all you needed.
Attached a zip file of the log
Thanks CC!
This looks like a bug in how the program is displaying the call grant.
As a side note, don't worry about the 68% decode rate. You're actually getting 100% - it is being under-reported by the program.
ccfd7031
Ok good deal!
Thanks for taking the time to look at it. I'm just getting familiar with the program. I hope to use it with my old tapped scanner in the future to log while I've got my 396xt listening.
