I have a solution for Trunking Recorder you can run multipliable instances of the program. But the remote.dll is just recording from voice and not my second vco. Will there be a solution to this?
The "scannerbox" guy (JasoVeen) specifically requested that the remote DLL API provide some means to distinguish individual VCOs so I believe he is working on this.
Saint
Fort Erie Ontario Canada
information
Hi Steve;
Please provide more detail. What receiver? How is it configured?
Hi, I had unitrunker 1.0.39.10 installed on my hp laptop running Windows 8.1. I downloaded the new release of Unitrunker and I had to set it up again for a first time run, so I did that and set up my receiver UBC245XLT and when I try and change the receiver from stopped to Running it will not do anything it just stays stopped, I uninstalled everything and re-installed 1.0.39.10 and did the same setup and everything is OK, I have no problem changing stopped to running.
Steve
Hi Matt!
noticed after a couple hours that a bunch of Radio IDs had populated into the group page.
Yuck. What system is this? To diagnose the problem, here's what I'd like you to do.
1. stop the signal receiver(s).
2. remove the radio IDs from the Groups tab.
3. turn of Decode logging on the signal receiver(s) (look for Logging check box on the VCO tab).
4. re-start the signal receiver(s).
5. when the radio IDs reappear on the Groups tab, stop the receivers and ...
6. please send me the decode logs.
You can post the logs here or send them to my gmail address.
Please also identify the erroneous group IDs. I can search the logs to figure out what went wrong.
Mattsenft
Harrisburg, PA
I enabled logging and have had some of the behavior occur again. I found a lot of files when I went looking for the log. What is the name or format of the log you want? I also didn't see your Gmail address on the Unitrunker website or here. I will email you the logs if you can point me where. Thanks.
The decode logs are prefixed "Decode". The name will include today's year, month and day.
Go to the signal receiver window and click on the folder tool button. If your receiver has multiple VCOs, the decode logs are named somerthing like DecodeA20150613.log (from the first VCO), DecodeB20150613.log (from the second VCO), DecodeC20150613.log (from the third VCO), and so on.
My gmail address is the same as my identity on radio reference.
Amraks
By the way group IDs on the system are 5 digits or less. All radio IDs are 7 digits.
Go to main window--> Info Tab --> scroll down to Apco 25 select Hex
All your radio ID's should change.
Not necessarily. Here's a channel grant with a low radio ID.
Code:
  00 00 04 2A 8D 2B 5D 00 07 D6 6D 93 Group Voice Grant channel 2-A8D I 0007D6 -> G 2B5D, (4 priority, packet)
7D6 = 2006 decimal which appears to be a valid four digit radio ID on this system.
Here's another grant with an equally valid high radio ID.
Code:
  00 00 44 2A 9C 2E 1B 7B CC 5E 5C E2 Group Voice Grant channel 2-A9C I 7BCC5E -> G 2E1B, (4 priority, packet protected)
Mattsenft
Harrisburg, PA
Ok, I sort of misspoke. For the purpose of this all the radio IDs that populated into the group ID are 7 digits. The only radio IDs in decimal that are less than 7 digits are consoles which are 4 as you saw above and a few test IDs that are 2. All normal users fit into a 7 digit scheme, Anything that populated into the group ID section that is 7 digits is erroneous.
jdd1957
Airspy will not Start
Thanks 10-75. What is the device name as displayed in the Unitrunker receiver window?
jdd1957 - what version of Windows is this?
Hi - I did not see the reply that I posted yesterday - I am running Win 7 Professional 64bit on a 4th gen I3. I can use the Airspy on both SDR# and SDR console.
I updated my Airspy firmware to RC5
Finally, I checked the Airspy driver and found an Open Moko driver 6.1.7600.16385. The instance ID is USB\VID_1D50&PID_60A1\AIRSPY_SN:16C463C83242A6C7
Not sure what else to provide
Heads up! I just uploaded a fix for the bug reported by Matt (mattsenft). The program was leaking radio IDs into the groups tab. It's a rather serious bug. Please update ASAP to 1.0.31.19.
I recently updated the harness utility to provide a little more information.
After you download and run the latest harness utility, please post the output here.
Saint
I'll look into this. Thanks Steve!
Thanks I see you have been very busy updating the Unitrunker program.
I tried reinstalling the program Windows 8.1 And on my old computer running Windows 7 And still can not change the receiver from stopped to running, have no problems with the old unitrunker program.
Steve
jdd1957
I have tried to clean the registry to remove the old usb device data. Then reconnected the Airspy. Here is the latest harness data
C:\Users\X\Downloads>harness
AirSpy Test Harness
(c) 2015 All Rights Reserved.
Found an AirSpy
0 Device: \\.\USB#VID_1D50&PID_60A1#AIRSPY_SN:16C463C83242A6C7 Friendly: Descri
ption: AIRSPY Serial: AIRSPY_SN:16C463C83242A6C7 Symbolic: \\.\IUSB3#ROOT_HUB30#
4&419A9D0&1 Interface: {A75D0CA9-F466-43e9-8725-2F9C3278019C}
Opening \\.\USB#VID_1D50&PID_60A1#AIRSPY_SN:16C463C83242A6C7 (\\.\IUSB3#ROOT_HUB
30#4&419A9D0&1), Opening.
CreateFile fails, File Not Found(2).
Closing.
Opening.
Setting Policies.
Gathering interfaces.
Found 0 associated interfaces.
succeeds with alternate path.
Board ID: AIRSPY
Part ID: 6906002b:00000030
Serial: 00000000:00000000:16c463c8:3242a6c7
Closing.
Closing \\.\USB#VID_1D50&PID_60A1#AIRSPY_SN:16C463C83242A6C7, succeeds.
Thanks jdd1957!
I've updated the program with this fix for AirSpy on some Windows 7 machines. Please download 1.0.31.20 and let us know how it works for you.
jdd1957
It Works!!!
Thanks jdd1957!
Rick,
Thanks very much for the program fix. I have three VCOs working perfectly with three systems. Feels really good to see it working.
Thanks for your efforts and contributions.
The Strangest thing happened to me after I downloaded the 1.0.31.20. That being my Health Meter stayed at zero, when on version 1.0.31.18 my Health Meter works.
What do you guys think that is?
By the way, I love the new look on the 31.20! Keep up the Great Unitrunker!
