unitrunker roaming
ate8888
#1
78turbo
Mossyrock, WA
#2
It may have the ability to chase control channels just by the system ID, linking to different sites as needed. I have never tried something like that to know if it would work.
#3
The short answer is no. The program isn't designed for a single VCO to scan control channels across multiple sites.
The Chase feature requires the site number, channel number and frequency to all be correct.
