Unknown freq on Ski Summit site
dw2872
Colorado
Does anyone know what the frequency/channel is for that is listed below the control channel on this site? The channel/freq listed in the screen shot is 01-2234 / 775.96875
I am thinking a repeater output or something like that?
greenthumb
Colorado DB Administrator
My guess is that they have added a 700 MHz channel to that site. Input is +30 MHz.
Mick
Western U.S.
Hi Dan, I've run Site 413 Ski Summit for the last 75 minutes and have not yet seen 775.96875 show up. I wonder if it's another anomaly for your version of Pro96 COM? I checked and am unable to locate an FCC license for 775.96875 anywhere in Colorado.
dw2872
Colorado
It is a good chance it is an anomaly with this version but that is a 700 interoperability frequency. When I get a chance to get to that computer that it is on then I will stop and restart it to see. When I first saw that this morning I did just that and it kept populating with that freq at the bottom. The problem is that it does not fill in the usage type column so I thought that was strange.
Tonight I am going to try to go back to the same version you have. I am tired of seeing things that might not be there.
Thanks for looking, Mick.
dw2872
Colorado
That makes sense. I will definitely regress to the older ProScan version that Mick is using and see what happens.
Steve2003
Colorado
The frequency will continue to show up in Pro96Com until you remove it from your Tower004013.txt file. If the frequency appears again then it might be worth researching further.
I run several instances of Pro96Com at the same time so screen space is a previous commodity. I'll periodically remove frequencies that have zero hit counts to conserve space (depending on your Pro96Com settings hit counts may not save between logging sessions).
dw2872
Colorado
That's awesome info and advice. I'll delete the freq or the whole tower file and see what happens. Thanks!
Mick
Western U.S.
Hi Dan, Just got home, Pro96COM has been running six hours on Site 413 and the 775 MHz freq never showed up. Just a quick thanks to my buddy Brian who got me started with Pro96COM in the last year or two, it's great.
