Unknown NFM signal, 8202.9 kHz, NFM, April 07, 2013, 1345 UTC
Token
Howdy all,
Not really sure what forum section this should go in, I am going to throw it in Shortwave Broadcast, although it is probably unintentional.
Several times over the past week or more I have noticed a narrow band FM signal around the 8200 kHz area. It has been on several different frequencies, 8006.3 kHz, 8202.9 kHz, 8206.3 kHz, 8263.1 kHz, and 8301 kHz. It generally is around S4 or S5 here, and the strongest I have seen it is S7. It has not been on 24 hours a day, but it has been on for hours at a time and both day and night. In the late evening it seems to drop out for me, but still be on the air, I suspect the freq is going long and the signal is going over me. There is fading on the signal at all times, it is up and down as one would expect.
Right now (April 07, 2013, 1545 UTC) the signal is on 8202.9 kHz, NFM.
When and how it changes freqs is unpredictable, but most of the time it seems to shift around the top or bottom of the hour.
For several days it was retransmitting XM Sirius sat radio channel “80’s on 8”, but today it is transmitting “90’s on 9”. Just the straight audio from Sirius XM, no added signals.
So, my first thought is a spur from something local. However searching from 10 kHz to 4 GHz there is nothing local playing this audio. OK, so a spur from something not local, so on the remotes I go to see where this signal is making it to. The remote in San Diego, CA, has the signal slightly less strong than I have it. A remote in WA has it weak but detectable. A remote in CO has it about half as strong as I do. A remote in MN has it detectable, but just above the noise floor. I cannot detect it on any remote east of there.
So, whatever it is it is not a small spur. There has to be at least a little power behind it. It is not local to me, although it is probably regional to me, say maybe in the southern California / Nevada / Arizona area.
Anyone else getting this signal? I would sure like to figure out the source, or at least the source area.
T!
(edit) ooops, I put 1345 UTC in the title, I meant 1545 UTC.
Token
Darth_vader
Yup, as of 2207 it's still there. (This is why I love tools like Global Tuners. ;o) Using the Ridgecrest, CA ("Mojave Desert") node.
Pretty drifty, but listenable.
Edit add:
@Token--
Whereabouts in WA?
Edit-add-edit-add:
I'm wondering if this might be some new commercial/government/commercial government SW broadcaster about to go on the air and they're just doing this to test their equipment. (Who knows, maybe NFM is destined to be the "analogue shortwave modulation format of the 2010s".) Or possibly a simulcast for some Navy unit at sea á la what AFRS are still doing in a few spots via SSB?
Token
Edit add:
@Token--
Whereabouts in WA?
Edit-add-edit-add:
Yes, the station has been on non-stop since I first saw it at 1300 UTC this morning, I left one of the radios here setting on freq all day just to see if it switched freq as it has in the past. At this time (0100 UTC, April 08, 2013) it has been on for more than 12 hours. If it does like it did last night it will stay on but at about 0300 UTC it will go long and drop out here.
Using the Mojave Desert node on GT you were using a radio less than 3 feet from the one I made the video with, and using the same antenna as in that video. So yes, the Mojave node has it about as well as my video ;)
It has been rather drifty. Across the day I have seen it as low as 8202.6 kHz, and as high as 8202.8 kHz.
Not sure exactly where the remote I used in WA was. It was a Perseus node and I think near Seattle.
This is not going to be an “official” station. This is almost certainly going to turn out to be an unintentional spurious emission from something. Unless someone local to it reads these posts and tunes into it the most likely outcome is that one day the source will figure out something is wrong, or change something unrelated, and poof, it will be gone without us ever knowing the source.
T!
