Unknown Packet
04Z1V6
Castle Rock, Co.
Hey guys I need a little help with this one I have been running pro96com and I let it go while scanning and under Unknown Packets this is what came up. What is this info and what do you do with it? I put back slashes were the column would be separated and the front slashes are to show a space were there is a space the Forum just crunched it all together.
Time \ Op \ Packet Data
09/10 12:02:05 \ 23 \ 23/ 09/ 00/ 01/ 8C/ 1B/ 80/ 00/ 00/ 00/ E7/ DE
Halfpint
Slightly NE of the People's Republic of Firestone
You might want to re-post this over in the `Trunking Control Channel Decoding' and possibly also the `Scanner Programming Software' forums in this order, too?
Just an `Olde Fart's' 2¢ worth? {WAN GRIN!}
greenthumb
Colorado DB Administrator
Generally when those unknown packets show up, they are vendor specific messages. The opcode (function ID or the message) on that one is 23 and the manufacturer's ID is 09, which means it's a vendor specific packet (are you sure it's not 90 instead? What system is this from?). Everything else up to E7 DE is the payload of the packet, and E7 DE is the TSBK CRC. These vendor specific messages are not publicly documented, so the program author displays them in case someone can correlate those packets with a specific feature or event to identify their use.
greenthumb
That's okay....I believe you. What site did you see this come off of? MFID 09 is Aselsan, Inc., which is weird to see. I wonder who is running Turkish radio equipment on DTRS? :)
04Z1V6
Castle Rock, Co.
See, I think I need to try and catch this again if I can. I hit so many towers from hear and sense it was scanning I have no Idea. I will see if I can find it in the log.
