Unknown Philadelphia TG
CommJunkie
FM19xr
#1
Edited because I got yelled at
Heard talk of Heroin, Cocaine, etc...so I can only assume this is a Narcotics TGID, but just wanted to double-check and see if anyone knew for sure. It's not listed in the DB.
Audiodave1
Chadds Ford, PA
#2
We do not list those TG's in the dB for the safety of those on the operations. The fact that you were able to hear it is a testament to the fact that sensitive groups have not been posted for all to see. Once that happens they WILL be back to full time encryption.
Medford, NJ
#3
I've heard a couple today...
ID 343, 439, and 664.
439 I'm hearing 19th district activity on.
These also seem odd as they are not in the normal sequence as most of the other PD TGID's.
CommJunkie
FM19xr
#4
If the operators are so concerned about their safety, they shouldn't be using clear, analong, unencrypted transmissions. It doesn't matter if the ID is listed on a database or not. It was picked up by my scanner. The fact that this ID didn't have a name tag on it didn't change the transmission any. They were clear and concise in their transmission. What difference does it make if I can hear them with an alpha tag or without one? It can still be heard. If it were a different frequency, maybe I wouldn't be so uptight about it, but they are on the same system as anyone else, so all the frequencies are already listed.
ok...I'm off my soapbox now.
California, PA
#6
Status bits, perhaps?
