Update DB
slingshot202
New Jersey
#1
I was unable to find this question / answer when doing a forum search, but, if one wished to submit an update to a database, how would one go about doing this?
I found a local BOE channel DMR CC using ProScan, thought maybe the DB should be updated. Let me know.
Gettysburg, Pa
#2
Go into the data base page where your info belongs.
At the top right, select "submit info" and type in your
data. The person who maintaines the list will then add
your info.....
