update
ameer2002
hi
i canot update for uniden 396xt
when update see : programming error
please check the following things.
*connect your scanners to your pc using the standed pc interface cable
why?
DaveIN
Founders Curmudgen
West Michigan
Did you remove the batteries, press and hold the 6 and L/O button while plugging in the power adapter?
Did you select the correct COM port from the pulldown? Are you using the Uniden USB-1 or a USB/Serial adapter with the supplied cable, or just a serial port? Did you unzip the update file?
ameer2002
Yes i remove batters and press the 6and l?o
i select the correct com port
i using a usb/serial adapter with cable
i did with winrar
what the proplem now?
kb8rvp
Michigan
Make sure that the com port is correct (try 1 then 2 then 3 then 4and so on) to see if you can connect and then once you figure out the correct com port make sure the speed setting matches the radio by pressing menu then turn the dial to settings press the volume knob and turn the dial to "set serial port" and press the volume knob again and check to see if it matches the settings in the firmware update tool. If it still fails try setting both the update screen and the scanner to a lower speed to see if you can get it to work until it works for you.
Mike
