update
mypoppa
Anderson,S.C.
I keep seeing this 1.4 update,but i can`t find out where it`s coming from.Nobody seems to know about this update for the pro96.
brian
DB Administrator
South Carolina
1.4 is functionally identical to 1.3. It's a manufacturing change only. There is no benefit to 1.4 over 1.3.
The only part of the -96's firmware that is user-upgradeable is the DPS firmware. Even if you wanted 1.4 for some reason, you'd have to send it back to the factory for the CPU upgrade.
