updated to dsdplus fastlane
sun
massachusett
i just recently updated to dsdfastlane. dsdplus event log window ok. i am having trouble with the dsdplus window . the window pop up ,but proceed to to a error messages. fmpx link ID 20001{server is not listening on selected link ID} do not know where the problem is.
slicerwizard
Toronto, Ontario
DSD+ is trying to connect to one of its FMP programs. If you're using something else, like SDR# or SDRuno, as a signal source, you need to make some changes via the DSD+ menus.
Using DSD+ with external signal sources
DSD+ can be used with external signal sources such as a properly discriminator-tapped receiver
or SDR software such as SDR#. To use DSD+ with these sources, use the menus in DSD+ to
select Passive Digital Monitor mode and then to select the audio input device that carries
the digital audio signal. When running in this mode, DSD+ can be used to monitor conventional
analog and supported digital signals; DSD+ will not directly support trunk tracking.
sun
massachusett
I look at all the posts on dsdplus fastlane ,and try some of the post solutions. I also followed the note text,that explained how to single dongle monitoring. I am using a sdrplay rsp 1a. I also add in the serial # in fmpp-cc.bat. So the note texts read,to use a single device,run 1R bat file to start dsd and then run sdrplay fmpp-cc.bat . when I do,a window pop up. It reads, Required file msvcr90.dll not found in current working folder. also try delete and reloading program. I had no issues using dsdplus with sdrplay rsp1A using sdruno. It only when I try updating to dsdplus fastlane.
air-scan
You're missing the required dll files found here
Download – DSDPlus
Download this DSDPlus v1.101 DLL Files
then extract everything into your DSD+ folder.
sun
massachusett
These downloads are in my dsd folder . I try many of times to delete and reload up into my dsd file. No luck
cg
Connecticut
If you are using FastLand, there is a separate download with a number of updated DLL files. Use those.
From DSDPlus menu, select MISC tab, last option, "Download Newest Base Files".
chris
sun
massachusett
thank you chris for your help. I think i fix
the msvcr90.dll problem. Now I am having problem with configuration on the fmpp.cfg file. I have a sdrplay rsp1A .I do not know how to configure it with the serial number.
cg
Connecticut
I don't have that SDR but i suspect it is similar to the Airspy
- You open the FMPP.cfg file using Notepad or other simple text editor
- type the serial number in the beginning of the line that says serial number list. If you have more than one, separate the serial numbers with a comma
- The first SDR serial number is used by the input -i1 and the second one is -i2, etc
chris
sun
massachusett
So I had so many issue with dsdplus fastlane ,trying to set it up.many days trying to figuring out.{ I am using a SDRPLAY rsp 1a}.THE FMPP 1.15 -i1-o2001 window pop up showing{this copy of Fmpp is for SDRPLAY service v3.07 was not dected.} did all the downloads to try and fix problem.
I think I still have my v3.06 on computer. Is any hope to fix this issus. thanks
slicerwizard
Toronto, Ontario
Does the RSP1A have a serial number? I thought they didn't have one.
What happens if you start FMPP.exe from Windows Explorer by double-clicking on FMPP.exe? Does it run ok?
If that works, try removing the entire -i parameter (-i1, probably) from whatever batch file you're using to start FMPP.
Also, the base files download in DSD+ should contain the 3.07 SDRPlay API DLL file that you seem to be missing. You also have to have the 3.07 API service installed and running on your PC.
sun
massachusett
I installed the sdruno 1.40.2 installer to my computer,to try and fix some issues with apiv3.07. Dsdplus application window continue to have the same issus.{as in the picture}. then try i open 1r dsd window and fmpp cc window. {As shown in picture} when sdruno is not running {the rsp1a works with it . Itry to open sdruno with rsp1a . It will not open with the rsp1a .It ask me to opennig with a wav file, Ican not get the to to work with each other.193 (2).jpg194.JPG195 (3).jpg
