Upgrade firmware for TYT-MD 380 questions
#1
Hi
Before I do firmware upgrade I want to make sure I am using the correct firmware.
Currently my Radio version is:
FIRMWARE VERSION : D002.034
CP VERSION: 0.127
I have no idea if this radio has GPS or not.
in the back it just says model : MD-380, output 5W, Frequency 400-480Mhz
looking at the steps here
Communic8 - How to upgrade firmware TYT MD-380
should I use the first or second
TYT MD-380 Firmware D013.020 New Vocoder Jul 16 2016 TYT Tytera MD-380 Firmware v13.20 Non GPS Version - Includes Firmware & Upgrade Software ( For radios with Firmware D013.xxx)
TYT MD-380 Firmware D003.020 Old Vocoder Jul 16 2016 TYT Tytera MD-380 Firmware v3.020 - Includes Firmware & Upgrade Software ( For radios with Firmware D003.xxx and D002.x xx)
chief21
Summer - western NC; Winter - Tampa Bay FL
#2
Hi
CP VERSION: 0.127
The last two lines of your post gives you your answer. It says 'For radios with firmware D003.xxx and D002.xxx.' You state that your current firmware version is D002.034 - Therefore, according to your post, you should use new version D003.020 to update your firmware.
John
