Upgraded Sentinel.. will not read SD Card
basking ridge nj
#1
this morning Sentinel said to upgrade... to Version 1.07.05, for my BCD436 and 536.
i upgraded.
Now, sentinel will not read my SD cards on either of my scanners, not even when plugged the SD cards are plugged into a card reader directly into the USB port of my windows 10 machine
any ideas??
basking ridge nj
#2
i also tried clear user data, read all drives... nothing.. it will not read the sd card.. however, it does "see" the scanner on the drive, just not the card. everything was fine until I upgraded the sentinel.
basking ridge nj
#3
i upgraded.
any ideas??
UPMan
Uniden Representative
Arlington, TX
#7
I cannot explain it. It has something to do with your PC's configuration. We had made C visible to accommodate someone. Then, we've had 2 people erase their C drives. All our test machines work OK, and all but 2 of our customer's machines (that we know of) work OK. And I've never seen this issue happen at all with Sentinel for the HP-1/2, which uses the same code and has been running since 2009.
basking ridge nj
#8
UPMAN... i am left with 2 scanners which cannot be programmed through sentinel. i need to go back to the previous sentinel software ..can you help with that ?? . i am out of any other ideas...
UPMan
Arlington, TX
#9
basking ridge nj
#10
its the same, when i hook up the scanner with the USB cable, and if I put the sd card right into a readrer:
"disk 4
removable
E:
7.40 GB
on line
FAT32
healthy
primary parttition
UPMan
Arlington, TX
#13
In "Clear User Data" with "Show All Drives" checked? (Won't show in other modes since it doesn't identify as a HomePatrol).
basking ridge nj
#15
and, just to prove my USB input and card reader works, I took a SD card out of my camera , and plugged it in.. and i can view all the photos on the sd card on my computer ("drive D)
Clark County Nevada
#16
I had a problem loading Favorite lists onto a brand new SD card today. With the new Sentinel Version downloaded and installed. I formatted the card with no problem. When I chose "write to scanner" it did not write the favorite lists I have in my profile. Sentinel had turned off DOWNLOAD and MONITOR in my profile for every favorite list without me knowing this. After finding this, I turned on DOWNLOAD and MONITOR in my profile and then my favorite lists were written to the SD card. I hope this may save someone else some time.
basking ridge nj
#17
UPman?? what else can I try? i need to be able to program these 2 scanners through sentinel. Everything was fine until this mornings sentinel update. now , its useless. I need these for my business.
